[gdal-dev] Topological pointer
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 5 14:02:25 PDT 2012
Nikhil,
>From the code it appears the TOPI field will be represented on the vector
primitives when you enable treating vector primitives as features. To
enable this you need to set the RETURN_PRIMITIVES=ON configuration option.
See the S57 driver page for some background.
http://www.gdal.org/ogr/drv_s57.html
It looks like the attributes will be named TOPI_0 and TOPI_1 and will be
integer fields containing the start and end point id I gather. The S57
topology support is a pretty fuzzy in my head. There is also other
topological information (I think) accessable on the vector primitive
features. Some likely as hard to use list attributes.
Best regards,
Frank
On Fri, Oct 5, 2012 at 11:06 AM, Nikhil Sai Parupalli <
nikhil.parupalli at iictechnologies.com> wrote:
> Hi All,
> We are working on project which renders S57 dataset , I used GDAL for
> rendering GIS data and DOTSPATIAL for displaying map.
> Here I could read dataset , but can any one know how do we get Topological
> Indicator value
> Thanks and Regards
> Note: Do not print this email until and unless it is really required.
> Save paper , stay Green
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121005/5e228d9e/attachment.html>
