[gdal-dev] clipping multiple shapefiles from a set of clipping polygons
Etienne Tourigny
etourigny.dev at gmail.com
Mon Oct 8 06:14:40 PDT 2012
generally speaking new features do not go into current stable version
(1.9), they will be incorporated into next stable version (probably
2.0).
Etienne
On Mon, Oct 8, 2012 at 9:57 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
> On 10/08/2012 03:21 PM, maning sambale wrote:
> Thanks! Is this implemented already in the stable build?
> It's currently only in the trunk version.
> Ari
> Maning Sambale (mobile)
> On Oct 8, 2012 7:28 PM, "Ari Jolma" <ari.jolma at gmail.com> wrote:
>> On 10/08/2012 02:13 PM, maning sambale wrote:
>>> HI,
>>> I have a shapefile polygon that contains administrative boundaries and
>>> a several shapefile of various features. I want to create separate
>>> shapefiles of each layer feature for each administrative boundaries in
>>> the clipping layer.
>>> For example,
>>> AdminPoly1
>>> - AdminPoly1_point.shp
>>> - AdminPoly1_line.shp
>>> - AdminPoly1_poly.shp
>>> AdminPoly2
>>> and so on.
>>> Any advice?
>> Maning,
>> The new layer methods may be what you're looking for:
>> http://trac.osgeo.org/gdal/wiki/LayerAlgebra
>> Ari
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
