[gdal-dev] +proj=etmerc in ogr2ogr
Simon Lyngby Kokkendorff
silyko at gmail.com
Mon Oct 8 13:19:13 PDT 2012
Hi Even,
Thanks a lot :-) I'll try the workaround and keep an eye open for when/if
the patch goes into trunk.
Cheers,
Simon
On Mon, Oct 8, 2012 at 10:07 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> > However, if I try to run ogr2ogr like:
> > ogr2ogr -s_srs "EPSG:25832" -t_srs "+proj=etmerc +lat_0=0 +lon_0=9
> > +k=0.9996
> > +units=m +x_0=500000 +datum=WGS84 +nodefs" C:\DHM\analysis\bakke2.shp
> > C:\DHM\analysis\shape\
> > bakke.shp
> > I get the following error:
> > Failed to process SRS definition: +proj=etmerc +lat_0=0 +lon_0=9
> +k=0.9996
> > +unit
> > It works fine if I change +proj=etmerc to +proj=tmerc. Seems to me, that
> > somehow +proj=etmerc is not build into the "metadata system" of gdal/ogr,
> > so that it is not translatable to e.g. a ESRI-wkt definition. Might this
> be
> > that case, and if so, what should I update in order to get this to work?
> Simon,
> When passing a proj.4 string to GDAL/OGR, it will try to construct a
> OGRSpatialReference object, which is a model of the WKT representation of
> the
> SRS. To be able to do that, it must recognize projection methods, and this
> is
> consequently hard-coded in ogr/ogr_srs_proj4.cpp.
> There's no code currently to recognized +proj=etmerc, hence the failure.
> However, there's a workaround. In GDAL 2.0dev, you could just add
> "+wktext" in
> the proj.4 string :
> $ testepsg "+proj=etmerc +lat_0=0 +lon_0=9 +k=0.9996 +units=m +x_0=500000
> +datum=WGS84 +nodefs +wktext"
> Validate Fails.
> WKT[+proj=etmerc +lat_0=0 +lon_0=9 +k=0.9996 +units=m +x_0=500000
> +datum=WGS84
> +nodefs +wktext] =
> PROJCS["unnamed",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["custom_proj4"],
> UNIT["Meter",1],
> EXTENSION["PROJ4","+proj=etmerc +lat_0=0 +lon_0=9 +k=0.9996 +units=m
> +x_0=500000 +datum=WGS84 +nodefs +wktext"]]
> The WKT representation built is somewhat invalid (see the "custom_proj4"
> PROJECTION), but it has a PROJ4 EXTENSION with the correct proj.4 string,
> hence the reprojection computations will work as expected.
> That syntaxic sugar is new to GDAL 2.0dev and doesn't work in previous
> versions. So for GDAL 1.9, you would have to put the above WKT into a file
> and
> use it as the -t_srs argument.
> The drawback of this is that the "custom_proj4" projection cannot be
> translated into something useful in a ESRI .PRJ file.
> The best is then to use a more standard WKT of a TM projection, but with
> the
> appropriate proj.4 extension with etmerc :
> PROJCS["unnamed",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["Meter",1],
> Let's suppose you put it into etmerc.wkt, then you can use :
> ogr2ogr -t_srs etmerc.wkt destination.shp source.shp
> Note that ogrinfo on the destination.shp will report standard TM, and will
> not
> have any more the etmerc method, so if you need to reproject afterwards,
> you
> will need to specify explicitely the etmerc.wkt again.
> I've opened the http://trac.osgeo.org/gdal/ticket/4853 ticket with a
> proposed
> patch to make things more user friendly. I haven't applied it yet, because
> I
> would appreciate FrankW's opinion to know if this is the right way of
> dealing
> with that. etmerc is something particular, since it isn't per se a
> projection,
> but rather a projection computation algorithm. I don't think that GDAL has
> already dealt with that kind of situation.
> Best regards,
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121008/6bc22ec7/attachment.html>
