[gdal-dev] clipping multiple shapefiles from a set of clipping polygons
maning sambale emmanuel.sambale at gmail.com
Wed Oct 10 03:57:41 PDT 2012
Dear Eli,
Thanks for this.  I tried your suggestion:
ogr2ogr -overwrite -f 'ESRI shapefile' clipped_roads.shp roads.shp
-clipsrc province.shp -clipsrclayer province -clipsrcsql 'SELECT *
FROM province WHERE provname='\''SomeName'\'''
ERROR 6: GEOS support not enabled.
More than 1000 errors or warnings have been reported. No more will be
reported from now
I am using GDAL 1.9 Complete frameworks from KyngChaos which has
includes GEOS 3.3.5-1
On Wed, Oct 10, 2012 at 12:14 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> ogr2ogr -f "ESRI shapefile" output.shp input.shp -clipsrc
> AdminPoly.shp -clipsrclayer AdminPoly -clipsrcsql "SELECT * FROM
> AdminPoly WHERE AttributeName_in_AdminPoly='Some_value'"
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
