[gdal-dev] S57 dataset boundary issue
s duclos sylvain_duclos at yahoo.com
Wed Oct 10 07:29:52 PDT 2012
Hi Nikhil,
I loaded US1GC09M//US1GC09M.000 .. it's huge :)
It's the Gulf of Mexico .. now where should I look ?
About the inner / outer ring. As I said before, I just assume that OGR
send me the outer ring first. And, up to now, my code is working fine.
rgds,
Sylvain.
----- Original Message -----
> From: Nikhil Sai Parupalli <nikhil.parupalli at iictechnologies.com>
> To: s duclos <sylvain_duclos at yahoo.com>; Frank Warmerdam <warmerdam at pobox.com>
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Sent: Wednesday, October 10, 2012 9:40:54 AM
> Subject: RE: [gdal-dev] S57 dataset boundary issue
> Could you try on this data set please
> Thanks and Regards
> Note: Do not print this email until and unless it is really required. Save paper
> , stay Green
> ________________________________________
> From: s duclos [sylvain_duclos at yahoo.com]
> Sent: Wednesday, October 10, 2012 7:02 PM
> To: Nikhil Sai Parupalli; Frank Warmerdam
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] S57 dataset boundary issue
> Nikhil,
> I loaded your ENC.
> I see a number of depth area (DEPARE) and anchor zone area (ACHARE).
> But no inner ring!
> Is there an inner rings somewhere I should see?
> rgds,
> Sylvain.
>>  Sent: Wednesday, October 10, 2012 8:00:41 AM
>>  Duclos,
>>  Please see this sample data attached.
>>  So as per the code given by you we have tried and got result i.e able to
> find
>>  out area
>>  some times it shows area<0 and some times area>0 hence we get  CW and
> CCW.
>>  But how do we classify in layer which is outer boundary and which is inner
>>  boundary
>>  Geometry testgeo = geomLAKARE.GetBoundary();
>>                                      double area = 0;
>>                                      for (int l = 0; l <
>>  testgeo.GetPointCount() - 1; l++)
>>                                          double x1 = testgeo.GetX(l);
>>                                          double y1 = testgeo.GetY(l);
>>                                          double x2 = testgeo.GetX(l + 1);
>>                                          double y2 = testgeo.GetY(l + 1);
>>                                          area += (x1 * y2) - (x2 * y1);
>>  Thanks and Regards
> paper
>>  , stay Green
>>  Sent: Tuesday, October 09, 2012 11:58 PM
>>  To: Frank Warmerdam; Nikhil Sai Parupalli
>>  Frank & Nikhil,
>>  Frank asked:
>>>  are, I'm not sure what I or others can do about
>>>  the performance cost of checking.
>>  If I understand the problem, then it cost nothing!
>>  You have to check the winding while loading a OGRGeometryH
>>  like so:
>>                  double area = 0;
>>                  for (unsigned int i=0; i<vert_count-1; i++) {
>>                      double x1 = OGR_G_GetX(hRing, i);
>>                      double y1 = OGR_G_GetY(hRing, i);
>>                      double x2 = OGR_G_GetX(hRing, i+1);
>>                      double y2 = OGR_G_GetY(hRing, i+1);
>>                      area += (x1*y2) - (x2*y1);
>>  If the area < 0 then it is CW (clockwise) and > 0 is CCW (Counter
> CW).
>>  Note that in S57 the exterior ring must be CW and
>>  interior ring are CCW.
>>  But in S57 there is no order between rings. So interior ring
>>  might come first. I think WKT fix this. In my code I assume
>>  that OGR place the exterior ring first.
>>  We have been trough this before. At the time the question
>>  was if S57 allow for many exterior ring for the same poly.
>>  I guess it all depend on HO and how they encode the data.
>>  I'm using mostly Canadian ENC and found no problem.
>>  But other HO might encode ENC differently ..
>>  rdgs,
>>  Sylvain Duclos.
>>>   From: Frank Warmerdam <warmerdam at pobox.com>
>>>  To: Nikhil Sai Parupalli <nikhil.parupalli at iictechnologies.com>
>>>  Sent: Tuesday, October 9, 2012 12:25:29 PM
>>>  On Mon, Oct 8, 2012 at 10:28 PM, Nikhil Sai Parupalli
>>  <nikhil.parupalli at iictechnologies.com> wrote:
>>>  HI All,
>>>>  Thanks for the reply in below data
>>>>    NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
>>>>     NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
>>>>     ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
>>>>     USAG (IntegerList) = (7:1,1,1,1,1,1,1)
>>>>     MASK (IntegerList) = (7:255,255,255,255,255,255,255)
>>>>   RCID 691 ORNT has  2 and USAG is 1 based on this data we could
> identify
>>  that RCID 691 is of exterior boundary with reverse direction.
>>>>  So if I have 1000 RCID in  NAME_RCID which is vise versa for the
> above
>>  condition I need to display that RCIDS list as errors.
>>>>  So it makes 1000 conditional checks hence reducing performance.
>>>>  Please let us know further.
>>>  Nikhil,
>>>  I'm afraid I don't follow your point.  Are you trying to
>>>  do some sort of ring orientation validation and identify
>>>  ones that don't match your expectations?  And you
>>>  are concerned about the performance cost?
>>>  I don't know why you are doing this, and if you
>>>  Best regards,--
>>>  I set the clouds in motion - turn up   | Frank Warmerdam,
>>>  light and sound - activate the windows | http://pobox.com/~warmerdam
>>>  and watch the world go round - Rush    | Geospatial Software Developer
>>>  _______________________________________________
>>>  gdal-dev mailing list
>>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
