[gdal-dev] S57 dataset boundary issue
s duclos
sylvain_duclos at yahoo.com
Wed Oct 10 08:13:37 PDT 2012
Hi Nikhil,
> Based on the code which you have sent we could find out CW and CCW, but not
> outer/inner
The outer ring of OGRGeometryH poly is the ring 0 (zero).
In C code the OGR call:
guint nRingCount = OGR_G_GetGeometryCount(hGeom);
will give you the number of rings in a poly.
Say there is 2 rings for this hGeom. Then the outer ring is
OGRGeometryH *hGeomRef_outter = OGR_G_GetGeometryRef(hGeom, 0);
and the inner ring is
OGRGeometryH *hGeomRef_inner = OGR_G_GetGeometryRef(hGeom, 1);
> Please have a look at that data set once and let me know.
There is nothing in attachment
rgds,
Sylvain.
----- Original Message -----
> From: Nikhil Sai Parupalli <nikhil.parupalli at iictechnologies.com>
> To: s duclos <sylvain_duclos at yahoo.com>; Frank Warmerdam <warmerdam at pobox.com>
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Sent: Wednesday, October 10, 2012 10:40:27 AM
> Subject: RE: [gdal-dev] S57 dataset boundary issue
> Hey Sylvain,
> Thanks for trying the data which I have sent.
> Could you be helping me how this works like outer boundary and inner boundary.
> outer/inner
> Or if you have any sample data with simple representation of outer and inner
> boundaries please do share with me.
> Thanks and Regards
> Note: Do not print this email until and unless it is really required. Save paper
> , stay Green
> ________________________________________
> From: s duclos [sylvain_duclos at yahoo.com]
> Sent: Wednesday, October 10, 2012 7:59 PM
> To: Nikhil Sai Parupalli; Frank Warmerdam
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] S57 dataset boundary issue
> Hi Nikhil,
> I loaded US1GC09M//US1GC09M.000 .. it's huge :)
> It's the Gulf of Mexico .. now where should I look ?
> About the inner / outer ring. As I said before, I just assume that OGR
> send me the outer ring first. And, up to now, my code is working fine.
> rgds,
> Sylvain.
>> Sent: Wednesday, October 10, 2012 9:40:54 AM
>> Could you try on this data set please
>> Thanks and Regards
> paper
>> , stay Green
>> Sent: Wednesday, October 10, 2012 7:02 PM
>> Nikhil,
>> I loaded your ENC.
>> I see a number of depth area (DEPARE) and anchor zone area (ACHARE).
>> But no inner ring!
>> Is there an inner rings somewhere I should see?
>> rgds,
>> Sylvain.
>>> Sent: Wednesday, October 10, 2012 8:00:41 AM
>>> Duclos,
>>> Please see this sample data attached.
>>> So as per the code given by you we have tried and got result i.e able
> to
>> find
>>> out area
>>> some times it shows area<0 and some times area>0 hence we get
> CW and
>> CCW.
>>> But how do we classify in layer which is outer boundary and which is
> inner
>>> boundary
>>> Geometry testgeo = geomLAKARE.GetBoundary();
>>> double area = 0;
>>> for (int l = 0; l <
>>> testgeo.GetPointCount() - 1; l++)
>>> double x1 = testgeo.GetX(l);
>>> double y1 = testgeo.GetY(l);
>>> double x2 = testgeo.GetX(l +
> 1);
>>> double y2 = testgeo.GetY(l +
> 1);
>>> area += (x1 * y2) - (x2 * y1);
>>> Thanks and Regards
> Save
>> paper
>>> , stay Green
>>> Sent: Tuesday, October 09, 2012 11:58 PM
>>> To: Frank Warmerdam; Nikhil Sai Parupalli
>>> Frank & Nikhil,
>>> Frank asked:
>>>> are, I'm not sure what I or others can do about
>>>> the performance cost of checking.
>>> If I understand the problem, then it cost nothing!
>>> You have to check the winding while loading a OGRGeometryH
>>> like so:
>>> double area = 0;
>>> for (unsigned int i=0; i<vert_count-1; i++) {
>>> double x1 = OGR_G_GetX(hRing, i);
>>> double y1 = OGR_G_GetY(hRing, i);
>>> double x2 = OGR_G_GetX(hRing, i+1);
>>> double y2 = OGR_G_GetY(hRing, i+1);
>>> area += (x1*y2) - (x2*y1);
>>> If the area < 0 then it is CW (clockwise) and > 0 is CCW
> (Counter
>> CW).
>>> Note that in S57 the exterior ring must be CW and
>>> interior ring are CCW.
>>> But in S57 there is no order between rings. So interior ring
>>> might come first. I think WKT fix this. In my code I assume
>>> that OGR place the exterior ring first.
>>> We have been trough this before. At the time the question
>>> was if S57 allow for many exterior ring for the same poly.
>>> I guess it all depend on HO and how they encode the data.
>>> I'm using mostly Canadian ENC and found no problem.
>>> But other HO might encode ENC differently ..
>>> rdgs,
>>> Sylvain Duclos.
>>>> From: Frank Warmerdam <warmerdam at pobox.com>
>>>> Sent: Tuesday, October 9, 2012 12:25:29 PM
>>>> On Mon, Oct 8, 2012 at 10:28 PM, Nikhil Sai Parupalli
>>> <nikhil.parupalli at iictechnologies.com> wrote:
>>>> HI All,
>>>>> Thanks for the reply in below data
>>>>> NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
>>>>> NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
>>>>> ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
>>>>> USAG (IntegerList) = (7:1,1,1,1,1,1,1)
>>>>> MASK (IntegerList) = (7:255,255,255,255,255,255,255)
>>>>> RCID 691 ORNT has 2 and USAG is 1 based on this data we
> could
>> identify
>>> that RCID 691 is of exterior boundary with reverse direction.
>>>>> So if I have 1000 RCID in NAME_RCID which is vise versa for
> the
>> above
>>> condition I need to display that RCIDS list as errors.
>>>>> So it makes 1000 conditional checks hence reducing
> performance.
>>>>> Please let us know further.
>>>> Nikhil,
>>>> I'm afraid I don't follow your point. Are you trying to
>>>> do some sort of ring orientation validation and identify
>>>> ones that don't match your expectations? And you
>>>> are concerned about the performance cost?
>>>> I don't know why you are doing this, and if you
>>>> Best regards,--
>>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>>> light and sound - activate the windows |
> http://pobox.com/~warmerdam
>>>> and watch the world go round - Rush | Geospatial Software
> Developer
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
