[gdal-dev] build error - conflicting cpl_serv.h
David Burken
dburken at comcast.net
Wed Oct 10 18:44:13 PDT 2012
Hi Everyone,
Just fyi, I can't build gdal with an external libgeotif without doing a
hack... Both gdal and libgeotiff from svn trunk. libtiff, geotiff were
installed in a fresh sandbox. Then configured gdal to use external
libtiff/geotiff.
I got gdal to build by removing the libgeotiff installed cpl_serv.h and
copying gdal/frmts/gtiff/libgeotiff/cpl_serv.h to gdal/port/cpl_serv.h
(in build include path). That's a hack I know but fixed. This was
broken before and fixed. Seems like it's back again.
Not an issue for me but I thought I'd report it... Error from build below.
Take care,
Dave
make[2]: Entering directory `/home/work/test/gdal/frmts/gtiff'
/bin/sh /work/test/gdal/libtool --mode=compile --tag=CXX g++ -g -O2
-Wall -I.. -I../jpeg -DHAVE_LIBJPEG -I/work/test/gdal/port
-I/work/test/gdal/gcore -I/work/test/gdal/alg -I/work/test/gdal/ogr
-I/work/test/gdal/ogr/ogrsf_frmts -DBIGTIFF_SUPPORT -DOGR_ENABLED
-D_REENTRANT -I/work/test/gdal/port -I/usr/local/ossim/include
-I/usr/local/ossim/include -c -o ../o/gt_wkt_srs.lo gt_wkt_srs.cpp
libtool: compile: g++ -g -O2 -Wall -I.. -I../jpeg -DHAVE_LIBJPEG
-I/work/test/gdal/port -I/work/test/gdal/gcore -I/work/test/gdal/alg
-I/work/test/gdal/ogr -I/work/test/gdal/ogr/ogrsf_frmts
-DBIGTIFF_SUPPORT -DOGR_ENABLED -D_REENTRANT -I/work/test/gdal/port
-I/usr/local/ossim/include -I/usr/local/ossim/include -c gt_wkt_srs.cpp
-fPIC -DPIC -o ../o/.libs/gt_wkt_srs.o
In file included from /work/test/gdal/port/cpl_port.h:84,
from /work/test/gdal/ogr/ogr_core.h:33,
from /work/test/gdal/ogr/ogr_srs_api.h:34,
from /work/test/gdal/ogr/ogr_spatialref.h:34,
from gt_wkt_srs.cpp:38:
/work/test/gdal/port/cpl_config.h:106:1: warning: "HAVE_STDLIB_H" redefined
In file included from /usr/local/ossim/include/cpl_serv.h:36,
from gt_wkt_srs.cpp:33:
/usr/local/ossim/include/geo_config.h:5:1: warning: this is the location
of the previous definition
/work/test/gdal/port/cpl_config.h:112:1: warning: "HAVE_STRING_H" redefined
/usr/local/ossim/include/geo_config.h:11:1: warning: this is the
location of the previous definition
gt_wkt_srs.cpp: In function 'CPLErr GTIFWktFromMemBuf(int, unsigned
char*, char**, double*, int*, GDAL_GCP**)':
gt_wkt_srs.cpp:2331: error: 'CPLString' was not declared in this scope
gt_wkt_srs.cpp:2331: error: expected ';' before 'osFilename'
gt_wkt_srs.cpp:2333: error: 'osFilename' was not declared in this scope
make[2]: *** [../o/gt_wkt_srs.lo] Error 1
make[2]: Leaving directory `/home/work/test/gdal/frmts/gtiff'
make[1]: *** [gtiff-install-obj] Error 2
make[1]: Leaving directory `/home/work/test/gdal/frmts'
make: *** [frmts-target] Error 2
