[gdal-dev] Data Set Parameter -reg
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Fri Oct 12 00:01:18 PDT 2012
Can any one help me out how to get Data Set Parameter  [DSPM] fieldfor S57dataset  into application using GDAL.
Do i need to change any system variables.
Thanks and Regards
Note: Do not print this email until and unless it is really required. Save paper , stay Green
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121012/d9f0b3f6/attachment.html>
