[gdal-dev] Problem with Gdal/ogr Java
Stefan Moebius
stefan.moebius at actix.com
Fri Oct 12 00:07:16 PDT 2012
Just for the record, it is not sufficient to have the DLL in the class path (actually this is not required at all).
The DLLs need to be on the application's search path.
The details can be found here:
http://www.chilkatsoft.com/java-loadLibrary-Windows.asp
Regards,
Stefan
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] On Behalf Of Imran Rajjad
> Sent: Wednesday, October 10, 2012 11:26
> To: Wael Tarhouni
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Problem with Gdal/ogr Java
> Hi Wael.
> you need to use gdal.jar file in your java project and also include
> the required DLL(Win) in your class path, then you will be able to
> use GDAL in your Java project.
> download from http://www.gisinternals.com/sdk/ or
> http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
> look for GDAL.JAR and the required DLL files in installed folder.
> regards,
> Imran
> On Wed, Oct 10, 2012 at 2:02 PM, Wael Tarhouni <waelinsat at gmail.com>
> wrote:
> > Good Morning,
> > I'm newbie in Gdal/ogr and i'm working actually with ogr2ogr Api to import
> > .TAB file(Mapinfo) into a postgis database, but i wanna make it automatic
> > without typing in command line or executing bat files. So, i found this
> > source code with gdal/ogr library :
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/ogr2ogr.java
> > but it doesn't work, is there any jar file of gdal/ogr to download ?
> > Best regards
> > Wael Tarhouni
> > Élève ingénieur en Réseaux informatiques et Télecommunication à l'INSAT
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I.R
Actix is the trading name of Actix Limited, with registered offices at:
200 Hammersmith Road, London, W6 7DL, United Kingdom.
Actix Limited is registered in England and Wales with company no.
02660615 and VAT no. GB 858742087. Managing Director of Actix Limited: Bill McHale.
Actix GmbH is registered in (Sitz der Gesellschaft): Dresden, Germany with company no. Handelsregister Amtsgericht Dresden
HR B 19204 and VAT no. (Ust-IDNr.) DE 813 115 475. Managing
Director of Actix GmbH (Geschaeftsfuehrer): Bill McHale.
Information in this message is confidential and may be legally
privileged. If you are not the intended recipient, please notify the
sender, and please delete the message from your system
immediately. The statements and opinions expressed in this
message are those of the author and do not necessarily reflect
those of Actix.
Whilst Actix takes every effort to ensure this message is virus
free it cannot guarantee that this is the case. It is the
recipient's responsibility to carry out such virus checks as
it deems necessary
