[gdal-dev] GDAL 1.9.2 not detecting options in ./configure
Even Rouault
even.rouault at mines-paris.org
Fri Oct 12 11:07:59 PDT 2012
> Any tips?
I haven't looked at all details, but most of the weirdness you see when
expliciting options is due that --with-bla (contrary to --with-bla-lib)
requires to just specify the installation prefix, and not prefix/lib. Except
when it is documented that it must point to /the/path/to/bla-config.
As I see you are using a 64-bit Fedora derived OS, there's an additional
difficulty. When specifying explicitely --with-bla=prefix, the libs will be
searched in prefix/lib, whereas those distros place them in prefix/lib64. So in
most case, if the prefix is /usr (or /usr/local), just specify --with-bla
without any path.
Due to the number of possible options, configuring GDAL can be indeed
challenging. You could take inspiration from the .spec file of the elgis
repository for example. Or when in doubt, open configure.in and study the
detection logic...
> thanks in advance
> Eduardo Patto Kanegae
> http://www.webmapit.com | @webmapit
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
