[gdal-dev] Help on using Ogr2ogr to load dxf data to postgis
Pietro Rossin pierigis at gmail.com
Mon Oct 15 01:18:10 PDT 2012
Hello
I wrote this question to Postgis user forum and they bounced me to this
group, so I hope to be more lucky this time..
I'm trying to load a thousand dxf files to postgis using ogr2ogr (windows xp
postgres9/postgis2).
the syntax I use is:
ogr2ogr --config DXF_INLINE_BLOCKS FALSE --config DXF_MERGE_BLOCK_GEOMETRIES
FALSE -f "PostgreSQL" PG:"host=localhost user=postgres dbname=mydbname
password=mypassword" mydxf.DXF -overwrite entities
This creates a table called entities that collect point and lines and a
geometry column wkb_geometry with a coord dimension integer 2 and a srid 0
My questions are:
Is there the possibility to filter unwanted layer from dxf before insert
them into the entities table via ogr?
and
is there the possibility to convert closed polylines to polygons and load
them to postgis?
and
how can I set the correct coord space (3D) and srid?
Thanks in advance
Pietro
View this message in context: http://osgeo-org.1560.n6.nabble.com/Help-on-using-Ogr2ogr-to-load-dxf-data-to-postgis-tp5008635.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
