[gdal-dev] ORA-01406 error when reading many attributes from Oracle
Eli Adam
eadam at co.lincoln.or.us
Tue Oct 16 10:34:58 PDT 2012
Jukka,
> Could it be possible that OCI driver reserves too little of some resourses and
> fails because of that with large records? I am now running a query with minimum
> set of columns in my query and ogr2ogr is running well and I believe it will
> convert all the million rows from the view now.
> The view schema does not look extra hard for me. There are 21 attributes in the
> view and the longest VARCHAR2 is just 100 chararters long.
This may be overly simplistic, but does the cast operator do anything?
SELECT *, CAST(OGR_STYLE AS character(255)) FROM rivers
Eli
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
