[gdal-dev] Using gdal_rasterize to mask ENVI file Using ESRI SHP format Vector
Wed Oct 17 15:22:02 PDT 2012
Peter,
I'm guessing you are using the gdal_polygonize.py script
for masking.  Is that right?  I am not aware of any particular
reason this shouldn't work for any "update in place" format
(ie. shows "rw+" in the gdalinfo --formats list).  ENVI is in
this list.
BTW, before we do a lot of work to investigate this you might
want to see if the problem persists with GDAL 1.9.  GDAL 1.6.3
is getting pretty antique.
Best regards,
Frank
On Wed, Oct 17, 2012 at 2:59 PM, Peter Willis <pwillis at aslenv.com> wrote:
> Hello,
> Is it possible to use ESRI SHP polygon file to mask
> ENVI  BSQ img format files with more than 1 band?
> I can mask a GTiff file using the SHP but ENVI file does not
> appear to work.  Gdal version is  1.6.3 .
> The documentation appears unclear for any raster that is not
> specifically GTiff.
> Thanks,
> Peter
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121017/b05c4a58/attachment.html>
