[gdal-dev] Using gdal_rasterize to mask ENVI file Using ESRI SHP format Vector [SEC=UNCLASSIFIED]
Pinner, Luke
Luke.Pinner at environment.gov.au
Wed Oct 17 16:10:32 PDT 2012
Perhaps something like
for i in {1..49}; do gdal_rasterize -burn -999 -b $i mask.shp 49bandenvi.dat; done
Luke
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Peter Willis
Sent: Thursday, 18 October 2012 9:43 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Using gdal_rasterize to mask ENVI file Using ESRI SHP format Vector
Hello,
On second thoughts, this is not really what I want.
I have a SHP format polygon vector file already.
I want to use that existing vector file to mask the ENVI format BSQ file through all (49) channels.
(ie: 'mask' meaning set any values inside vector polygons to a specific value within the output ENVI BSQ file )
Perhaps I'm missing something...
Peter
From: fwarmerdam at gmail.com<mailto:fwarmerdam at gmail.com> [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: October-17-12 3:22 PM
To: Peter Willis
Cc: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Peter,
I'm guessing you are using the gdal_polygonize.py script
for masking. Is that right? I am not aware of any particular
reason this shouldn't work for any "update in place" format
(ie. shows "rw+" in the gdalinfo --formats list). ENVI is in
this list.
BTW, before we do a lot of work to investigate this you might
want to see if the problem persists with GDAL 1.9. GDAL 1.6.3
is getting pretty antique.
Best regards,
Frank
On Wed, Oct 17, 2012 at 2:59 PM, Peter Willis <pwillis at aslenv.com<mailto:pwillis at aslenv.com>> wrote:
Hello,
Is it possible to use ESRI SHP polygon file to mask
ENVI BSQ img format files with more than 1 band?
I can mask a GTiff file using the SHP but ENVI file does not
appear to work. Gdal version is 1.6.3 .
The documentation appears unclear for any raster that is not
specifically GTiff.
Thanks,
Peter
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com<mailto:warmerdam at pobox.com>
and watch the world go round - Rush | Geospatial Software Developer
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121017/1613db2c/attachment.html>
