[gdal-dev] Why have I got SRS 900914 in my PostGIS table after ogr2ogr alimentation ?
SAEZ Laurent - SG/SPSSI/CPII/DOM/ETER/PNE IG
Laurent.Saez at developpement-durable.gouv.fr
Tue Oct 23 03:57:26 PDT 2012
I used to populate my PostGIS databases using ogr2ogr (GDAL 1.9.0,
released 2011/12/29 compiled by myself on Bedian).
It's the first time I've got this behavior: SRS isn't which I expect.
It's replaced by code 900914 in my table definition :
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 900914
I don't understand why...
This issue occured with EPSG:4467.
PostgreSQL 9.1.2, PostGIS 1.5.3, GDAL 1.9.0 run on the same server.
If I do : gdalsrsinfo "EPSG:4467"
It returns :
PROJ.4 : '+proj=utm +zone=21 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
+units=m +no_defs '
OGC WKT :
PROJCS["RGSPM06 / UTM zone 21N",
GEOGCS["RGSPM06",
DATUM["Reseau_Geodesique_de_Saint_Pierre_et_Miquelon_2006",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","1038"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4463"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-57],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","4467"]]
It's correct !!! But at this point, I don't know from where comes this
OGC WKT definition ?
This is one of my ogr2ogr commands :
ogr2ogr -f "PostgreSQL" -append -nln "mytable" -nlt MULTILINESTRING -lco
GEOMETRY_NAME=the_geom -lco FID=gid -lco OVERWRITE=no -a_srs EPSG:4467
PG:"dbname='MyDataBase' host=localhost port='5432' user='MyUser'
password='MyPassword'" MyMIFMIDFile
Usually it works ;-(
I have verified some files :
- Proj.4 epsg file : /MyFolder/share/proj/epsg :
It contains the following line :
<4467> +proj=utm +zone=21 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs
- GDAL pcs.csv : /MyFolder/share/gdal/pcs.csv
4467,"RGSPM06 / UTM zone
21N",9001,4463,16021,9807,1,0,4400,8801,0,9102,8802,-57,9102,8805,0.9996,9201,8806,500000,9001,8807,0,9001,,,,,,
- spatial_ref_sys from my database :
4467;"EPSG";4467;"PROJCS["RGSPM06 / UTM zone
21N",GEOGCS["RGSPM06",DATUM["Reseau_Geodesique_de_Saint_Pierre_et_Miquelon_2006",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","1038"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4463"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-57],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","4467"],AXIS["Easting",EAST],AXIS["Northing",NORTH]]";"+proj=utm
+zone=21 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs "
I have also try to add -a_srs EPSG:4467 to my ogr2ogr command but
without success !
Any idea ?
Regards
Laurent
