[gdal-dev] Question about using crop_to_cutline
António Rocha antonio.rocha at deimos.com.pt
Wed Oct 24 08:19:45 PDT 2012
Greetings
I have a raster image and a shapefile polygon and I wanted to crop the
raster for just to have valid pixels inside the polygon. I have used
crop_to_cutline but here is a problem:
It produces a raster map but pixels does not geographically match with
the original raster map. So, i produce a raster map but I'm not able to
compare with original image since there is a small displacement. How can
I obtain a raster map without this mismatch?
Thank you
Regards,
Antonio
GDAL version 1.9.1
