[gdal-dev] How to cut a Raster map with a KML file
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Sep 3 09:10:09 PDT 2012
Luis,
gdalwarp has some options for this exact purpose.
The cutline can be from any of the OGR readable datasource.
http://www.gdal.org/gdalwarp.html
On Mon, Sep 3, 2012 at 9:34 PM, Luis Lisboa <luislisboa1975 at gmail.com>wrote:
> Greetings
> I have a raster file (Geotiff) and I have a KML file with a polygon and I
> want to cut raster map to only have valid values inside the polygon. How
> can I do this using just GDAL?
> Usually I used to cut geotiff file with gdalwarp and but in those cases I
> was cutting a square (xmin xmax ymin ymax) and in this case is a more
> complex polygon
> Thanks
> Regards,
> Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120903/f01bb28c/attachment.html>
