[gdal-dev] ogrinfo sql UPDATE
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Wed Sep 5 14:23:42 PDT 2012
Hi
I would like to insert a column in a shape file and insert a specific
value on it.
I  succeed in insert the column by ogrinfo and sql by
ogrinfo wyoming.shp  -sql 'ALTER TABLE wyoming ADD COLUMN area real'
but than i  did not succeed in inserting the value.
ogrinfo wyoming.shp  -sql 'UPDATE wyoming SET area=1000  WHERE area is NULL'
ERROR 1: SQL Expression Parsing Error: syntax error
Is sql update supported or i miss something?
Thanks
Giuseppe
Giuseppe Amatulli
Web: www.spatial-ecology.net
