[gdal-dev] DBF file associated with Raster
Even Rouault even.rouault at mines-paris.org
Thu Sep 6 09:05:32 PDT 2012
Selon Ivan Lucena <ivan.lucena at princeton-ma.us>:
> Hi Alisson,
> How did that dbf was create?
> Can you run ogrinfo and report it back to us?
> gdalinfo file-name.dbf
Ivan certainly meant : ogrinfo file-name.dbf
> Is there a .shp file associated with that dbf?
To my knowledge, there's no GDAL driver that directly manages attributes that
would be associated and contained in a DBF file. The correlation between the
raster and attribute information must be done by the user and/or other tools.
> Regards,
> Ivan
> >  -------Original Message-------
> >  From: Alisson Barbosa <alisson.uece at gmail.com>
> >  To: gdal-dev at lists.osgeo.org
> >  Subject: [gdal-dev] DBF file associated with Raster
> >  Sent: Sep 06 '12 08:59
> >  Hi,
> >  I want to know how to read the attributes of a dbf file associated with a
> >  raster using GDAL.
> >  Regards,
> >  Alisson Barbosa
> >  Systems Analyst - FUNCEME - Brazil
> >  _______________________________________________
> >  gdal-dev mailing list
> >  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
> >  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
