[gdal-dev] gdal dataset
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Sep 7 00:20:48 PDT 2012
Neelima,
Perhaps I didn't understand your question.
You said that it was asking for a dataset. How did it ask?
What were the error messages you got?
In your future queries, please include as much information as you can
provide.
On Fri, Sep 7, 2012 at 12:42 PM, Neelima Emmani <
neelima.emmani at iictechnologies.com> wrote:
>  Hi Chaitanya,
> How did you  do that. What version of gdal are you using. Can you please
> share your code snipplet with me.
> With Regards,
> Neelima Emmani
> *From:* Chaitanya kumar CH [chaitanya.ch at gmail.com]
> *Sent:* Friday, September 07, 2012 12:04 PM
> *To:* Neelima Emmani
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] gdal dataset
>  Neelima,
> For me specifying the .000 file to ogrinfo and ogr2ogr worked.
> On Fri, Sep 7, 2012 at 11:32 AM, Neelima Emmani <
>>  Hi All,
>> I have generated gdal , ogr , osr dlls and added them to my c# project.
>> Now i am trying to run the application that is given in gdal download which
>> is named as gdalread.cs.When I run it , it is asking for a dataset . Can
>> any one let me know if i have to specify filename over here. Actually i
>> want to read enc file which has s57 datset. So, I am confused if i need to
>> specify filelname or s57 over here.
>> Awaiting reply.
>> With Regards,
>> Neelima Emmani
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120907/3ed3173f/attachment.html>
