[gdal-dev] Layer creation option FID (Spatialite, MSSQL)
Jeremy Palmer JPalmer at linz.govt.nz
Sun Sep 9 21:29:29 PDT 2012
Any limiting factors in improving the Spatialite and MSSQLSpatial drivers to allow defining the feature ID column LCO like the PostgreSQL (FID) or FileGDB (OID_NAME) drivers?
Also, do Spatialite, MSSQL user defined tables with PKs already set work correctly in OGR?
Thanks
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
