[gdal-dev] Layer creation option FID (Spatialite, MSSQL)
Jeremy Palmer
JPalmer at linz.govt.nz
Mon Sep 10 17:37:08 PDT 2012
> Yes it could be implemented. The limiting factor is the available spare time ;-)
Thanks - that's what I thought.
> What do you mean by "working correctly"? Did you find issues?
No I only looked at the code and didn't actually test it. I just wanted to ask the devs to determine if this was possible.
Thanks
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
