[gdal-dev] MUTEX_NONE question
Martin Chapman
chapmanm at pixia.com
Tue Sep 11 13:08:42 PDT 2012
If I don't want to use GDAL in thread safe mode on Windows can just define
MUTEX_NONE in the nmake.opt file? If not, is there a way I can do it.
Also, I want to avoid caching. Can I just define the env var
GDAL_FORCE_CACHING and set it to NO? Will that also avoid any thread
synchronization?
Best regards,
Martin Chapman
Software Developer
Pixia Corp.
45615 Willow Pond Plaza
Sterling, VA 20164
Main - 571.203.9665
Cell - 303.324.1065
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120911/9d78f919/attachment.html>
