[gdal-dev] How to cut a Raster map with a KML file
Luis Lisboa luislisboa1975 at gmail.com
Wed Sep 12 01:31:54 PDT 2012
Hello Jorge (portuguese?)
The problem is not the KML. GDALwarp supports the usage of KML to cut
Raster file. The thing is that it generates a Geotiff file with two bands:
1 with the masked values and another with just value of 1 in the valid
pixels (a bitmask). Is it possible to generate a geotiff with onluy the
first band?
Thanks
Luis
On Tue, Sep 11, 2012 at 8:25 PM, Jorge Santos <jorgepsantos2002 at gmail.com>wrote:
> Hey, you can convert the KML to shapefile with *ogr2ogr* and use this
> shape to cut the raster data.
> STEP01: Convert a single KML to Shapefile:
> *ogr2ogr -f "ESRI Shapefile" output_shapefile.shp input_kml_file.kml*
> STEP02: Crop the raster with polygon shapefile with gdalwarp. This command
> will crop the raster by extent of shapefile:
> *gdalwarp -crop_to_cutline -cutline output_shapefile.shp input_raster.tif
> clipped_raster.tif*
> PS: -crop_to_cutline   =>  GDAL >= 1.8.0<http://www.gisinternals.com/sdk/>required
> cheers
> Jorge Santos
> 2012/9/11 Luis Lisboa <luislisboa1975 at gmail.com>
>> Hi Eli
>> Probably I was not clear: When I use this it outputs a geotiff with two
>> bands: 1 with the real data and another one with the mask of the pixels
>> that fall inside each polygon. I just want to have an output file with one
>> band (band 1) and without the mask. Is it possible?
>> Thanks
>> Luis
>> On Thu, Sep 6, 2012 at 4:50 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>>> Luis,
>>> On Wed, Sep 5, 2012 at 3:00 AM, Luis Lisboa <luislisboa1975 at gmail.com>
>>> wrote:
>>> > Thank you Chitanya.
>>> > But it created an output file with two layers (one with the values from
>>> > original file and another with a 255 for the pixels thar are inside KMZ
>>> > file: How can I have produce one layer?
>>> I may be thinking of something else based on your description.  If you
>>> got an output that has the original values in the area of the kmz and
>>> an alpha mask band over the other areas I think that would be
>>> expected.  You can also use -crop_to_cutline to remove that 'extra'
>>> data.
>>> If that isn't what you are talking about, you may want to use ogr2ogr
>>> to convert your kmz to a shapefile in the same projection as your
>>> input raster and see if it gives you a better result.
>>> Bests, Eli
>>> > Thanks
>>> > Luis
>>> > On Mon, Sep 3, 2012 at 5:10 PM, Chaitanya kumar CH <
>>> chaitanya.ch at gmail.com>
>>> > wrote:
>>> >> Luis,
>>> >> gdalwarp has some options for this exact purpose.
>>> >> The cutline can be from any of the OGR readable datasource.
>>> >> http://www.gdal.org/gdalwarp.html
>>> >> On Mon, Sep 3, 2012 at 9:34 PM, Luis Lisboa <luislisboa1975 at gmail.com
>>> >> wrote:
>>> >>> Greetings
>>> >>> I have a raster file (Geotiff) and I have a KML file with a polygon
>>> and I
>>> >>> want to cut raster map to only have valid values inside the polygon.
>>> How can
>>> >>> I do this using just GDAL?
>>> >>> Usually I used to cut geotiff file with gdalwarp and but in those
>>> cases I
>>> >>> was cutting a square (xmin xmax ymin ymax) and in this case is a more
>>> >>> complex polygon
>>> >>> Thanks
>>> >>> Regards,
>>> >>> Luis
>>> >>> _______________________________________________
>>> >>> gdal-dev mailing list
>>> >>> gdal-dev at lists.osgeo.org
>>> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> >> Best regards,
>>> >> Chaitanya kumar CH.
>>> >> +91-9494447584
>>> >> 17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120912/82bde2aa/attachment-0001.html>
