[gdal-dev] ECW support on Fedora Linux - error
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Wed Sep 12 14:48:37 PDT 2012
Hi Johan,
Johan Hedin <johan.o.hedin at gmail.com> wrote:
>Thanks for the hint Jeff. I will definitely update the ECW wiki as
>soon as I get time!
>I'm working on collecting as many patches regarding libecwj2 and linux
>as I can find to get the lib to build cleanly on modern linux
>distributions.
Many of the various patches floating around are applied to the Arch Linux libecwj2 package available at
<https://aur.archlinux.org/packages.php?ID=38915> which might save you time. I'll notify the package maintainer about this latest one.
Regards,
Homme
>Regards Johan
>2012/9/12 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
>> You might add your notes (and even attach your patch) to the ECW
>> buildhints wiki page for GDAL yourself:
>> http://trac.osgeo.org/gdal/wiki/ECW (otherwise emails are long
>forgotten)
>> Works great for your FOSS4G karma as well!
>> Thanks,
>> -jeff
>> On 12-09-12 5:09 PM, Johan Hedin wrote:
>>> I had the same problem with libecwj2-3.3 and Fedora 17 64-bit
>>> yesterday. I tracked this down and it is a bug in libecwj2 itself
>>> regarding wchar_t handling in the file NCSPrefsXML.cpp.
>>> I have attached a patch to this mail to fix this. It is a super
>simple fix :-)
>>> Another way around this is to just define the environment variable
>>> NCS_USER_PREFS to point to some bogus file name. If this is done the
>>> code take another path in libecwj2 and the bug is not triggered. But
>>> fixing the bug is of course better.
>>> BTW, this has apparently always been a bug and I guess that is has
>>> started to show now due to updates to libstdc++, c++ compilers etc.
>In
>>> the beginning of Fedora 16 this worked but on a up-to-date Fedora 16
>>> today the behaviour is the same as on Fedora 17.
>>> All distributions that are updating c++ and/or libstdc++ in the
>future
>>> will probably see this bug as well. My patch is not fedora specific.
>>> Pleas report back here if this patch is working for you as well!
>>> (Small disclaimer: I'm recreating the patch from my head. I don't
>have
>>> the running instance of gdal with ECW support on this computer)
>>> Regards Johan
>>> 2012/9/11 lanufabi <dasfabirad at googlemail.com>:
>>>> In reply to this post by jkadlec
>>>> Hey,
>>>> I compiled libecwj2 and gdal 1.9.1 on arch linux like "jkadlec" did
>and get
>>>> the same error when i use gdalinfo for ecw files:
>>>> terminate called after throwing an instance of 'std::length_error'
>what():
>>>> basic_string::_S_create
>>>> gdalinfo --formats puts out that ECW is supported.
>>>> What can I do to identify the problem? Do you know a solution?
>>>> Thanks
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
