[gdal-dev] Warp to GeoTIFF with Transparency?
Even Rouault
even.rouault at mines-paris.org
Tue Sep 18 14:12:26 PDT 2012
Le mardi 18 septembre 2012 05:15:03, Nik Sands a écrit :
> I'm very new to GDAL so please be gentle. My searching has found many
> references to this problem, but no complete solutions that are explained
> clearly enough for me to work through.
The Warp API is powerful, and thus admitedly complex to master.
> I'm using the GDAL API to read in a source image (could be from a variety
> of formats), warp it to Spherical Mercator, and then write out the
> reprojected image as a GeoTIFF. I would like the parts of the warped TIFF
> that are not included in the original image to be represented by fully
> transparent pixels instead of the black pixels that are being generated.
> I've set "ALPHA" to "YES" in the warp options but this has not helped.
> I've also tried adding an extra transparent band, but this made the entire
> output image transparent.
Strange, perhaps you should retry.
To have a transparency band added in the output of the warping, you need to
set the band number in the GDALCreate() call to 1 +
GDALGetRasterCount(hSrcDS), and also set psWarpOptions->nDstAlphaBand = 1 +
This should be equivalent to the -dstalpha option of gdalwarp. By the way, if
I were you, I would try to find the gdalwarp command line that fits my need, and
then study its code source to extract what is needed for your use case.
