[gdal-dev] gdal_rasterize in parallel processing
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Tue Sep 25 08:47:20 PDT 2012
Hi all,
I solved the down reported issues. I change -ot Float32 to -ot
Float64 and it works.
Anyway Float32 should be enough to store the max value of
560459513003129 < 3.4E38
but probably during the multi-core several values are stored in the
same array and it needs Float64.
ciao ciao
Giuseppe
On 24 September 2012 17:53, Giuseppe Amatulli
<giuseppe.amatulli at gmail.com> wrote:
> Hi,
> i'm running gdal_rasterize for several *.shp using xargs, sending
> the process to 10 cpu.
> 1) ls /weldgfs/p51/gius_urban/pop_urban/2010/shp_albers/*.shp |
> xargs -n 1 -P 10 bash
> /weldgfs/p51/gius_urban/pop_urban/scripts/sc2a_shp_rasterizeP30_2010.sh
> the same process can be run using one processor.
> 2) ls /weldgfs/p51/gius_urban/pop_urban/2010/shp_albers/*.shp |
> xargs -n 1 -P 1 bash
> Inputs and outputs are independent in each process so no issues in
> reading/writing the same file.
> The obtained tifs produced by the gdal_rasterize
> (gdal_rasterize -a_nodata 0 -ot Float32 -co 'COMPRESS=LZW' -te
> $geo_string_tif -tr 30 30 -l $filename -a BLOCKID10
> $INDIR/$filename.shp $OUTDIR/$filename"_"$tile".tif" ;
> where BLOCKID10 is an integer number if e.g 550 019 505 012 101 )
> should be same but is not the case.
> Line 2) produce the tif perfect similar with the attribute of the shp;
> so no issues.
> Line 1) burn the same BLOCKID10 value for several polygons, resulting
> in less final polygons.
> Seems to me that this phenomena manly effect BLOCKID10
> values having several "0" (e.g. 10979900000033 ; 10030101002035)
> May question is. Can be possible that the gdal driver used inside C
> code not support multi-core processing?
> If yes it is possible to find a solution to run gdal_rasterize in parallel.
> Any idea?
> Thanks in advance
> Giuseppe
> Web: www.spatial-ecology.net
Giuseppe Amatulli
