[gdal-dev] SetColorTable() issues on GTiff with python bindings
Ivan Lucena
ivan.lucena at princeton-ma.us
Thu Sep 27 07:29:47 PDT 2012
Have you tried with GDT_Byte data type?
> -------Original Message-------
> From: Ingmar N <initze at ucc.ie>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] SetColorTable() issues on GTiff with python bindings
> Sent: Sep 27 '12 09:12
> Hello,
> I would like to add a Colortable to a GeoTiff. Running the SetColorTable()
> function, python returns "3". GetColorTable() returns empty, no colortable
> is attached.
> After browsing the internet for a solution, I tried to run the procedure on
> a newly created GTiff (which was often suggested). Probably any issues with
> the colortable?
> The file is not Write-protected or problematic otherwise, WriteArray() for
> example works without any problem.
> ds2=dr.Create('C:\\testfolder\\X.tif',ds.RasterXSize,ds.RasterYSize,1,gdal.GDT_Int16)
> ct=gdal.ColorTable()
> ct.CreateColorRamp(0,(178,223,138),5,(255,127,0))
> outband=ds2.GetRasterBand(1)
> outband.SetColorTable(ct) # returns 3
> Versions:
> python 2.7
> gdal 1.9.1
> Any Suggestions?
> Thanks for your help
> View this message in context: http://osgeo-org.1560.n6.nabble.com/SetColorTable-issues-on-GTiff-with-python-bindings-tp5004969.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
