[gdal-dev] Feature request: gauss and other interpolations in gdalwarp
John Twilley
mathuin at gmail.com
Sun Apr 7 23:17:32 PDT 2013
Thank you, Etienne, for writing this code. I greatly appreciate it!
I updated my svn checkout, then applied your patch with no errors. I tried
to warp my landcover files which use color tables (which is why mode is so
important to me) and they did not work. Here is the output:
jmt at nala:~/git/mathuin/TopoMC$ /home/jmt/svn/gdal/apps/.libs/gdalwarp
--debug -multi -tr 6 6 -te 2087232 2395968 2104512 2410176 -r mode
regions/Provincetown/Datasets/L1L.tif L1L-new.tif
Copying color table from regions/Provincetown/Datasets/L1L.tif to new file.
Creating output file that is 2880P x 2368L.
Processing input file regions/Provincetown/Datasets/L1L.tif.
Warning: Input file regions/Provincetown/Datasets/L1L.tif has a color
table, which will likely lead to bad results when using a resampling method
other than nearest neighbour. Converting the dataset prior to 24/32 bit is
advised.
ERROR 5: GDALWarpOptions.Validate()
eResampleArg=6 is not a supported value.
Let me know if I can provide any additional information to help you out!
Jack.
mathuin at gmail dot com
On Sun, Apr 7, 2013 at 1:19 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> I have implemented mode and average warping algorithms, based on those
> used in overview creation.
> http://trac.osgeo.org/gdal/ticket/5049
> This code has been tested on a few datasets (see attachments) with all
> datatypes (Byte, Int, Float) but not all cases have been looked into (e.g.
> color tables, various projections).
> Any feedback and testing would be appreciated.
> Cheers
> Etienne
> On Wed, Mar 27, 2013 at 6:13 PM, John Twilley <mathuin at gmail.com> wrote:
>> I'm interested in this feature request as well. Adding the mode
>> resampling algorithm to gdalwarp would be very beneficial to my projects,
>> right up there with being able to access the warp API from Python. Is this
>> at all possible? Should I submit a feature request on Trac, or what? Just
>> let me know!
>> Jack.
>> On Mon, Feb 18, 2013 at 8:17 AM, Jan Hartmann <j.l.h.hartmann at uva.nl>wrote:
>>> Hi devs,
>>> Would it be possible to add gauss and other interpolations to gdalwarp?
>>> At the moment I georeference large scans to 2000*2000 tiles at the most
>>> detailed scale, and then create 2000*2000 tiles at resolutions of 2, 4 6
>>> etc times the original scale, using gdaladdo and gauss or other
>>> interpolations. It would help immensely if I could do that directly with
>>> gdalwarp.
>>> Funding would probably no problem. The question is: can and should it be
>>> done?
>>> Jan
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130407/01f36640/attachment.html>
