[gdal-dev] Compile GDAL/OGR with SOSI support
SBL Stefan.Blumentrath at nina.no
Mon Apr 8 04:16:22 PDT 2013
Hi
Can somebody give me a hint on how to compile GDAL/OGR with support for the
Norwegian SOSI format?
I tried to find a solution in http://trac.osgeo.org/gdal/ticket/3638 as good
as I can, but without success...
I do have the (binary version of the) fyba library, but there is no
--with-sosi option (neither in GDAL 1.8 nor 1.9) when configuring GDAL...
I also tried:
CFLAGS="-DSOSI_ENABLED" ./configure
But compiling GDAL that way did not ask for libfyba and there is no support
for SOSI with GDAL/OGR compiled and installed that way...
SOSI is not listed after configuration and neither on:
ogrinfo --formats
Consequently, ogrinfo does not read .sos files either...
Do I have to link to libfyba when compiling and if so, how?
I am grateful for any help!
Cheers
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/Compile-GDAL-OGR-with-SOSI-support-tp5045207.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
