[gdal-dev] OGR field names encoding and SetAttributeFilter
Dennis Gocke dengo at gmx.net
Tue Apr 9 02:01:19 PDT 2013
Thanks Even.
It's strange that the SQL parser does not accept non-ASCII literals when
writing "FieldName = .." but when writing
"'Fieldname' = .." it does. It think this is not good, because it more or
less encourages the wrong use of ' when specifying field names.
Is there a reason for this strange behaviour that I'm missing? Perhaps this
is because without the ' it would confuse the SQL parser when some special
literals are within the field name (e.g. spaces).
I just noticed you can also use " when specifying field names in OGR, so
it's not so bad. This is for instance like in ArcMap, but there " can only
be used when specifying field names and not for specifying strings where '
needs to be used. It would be nice if OGR would differentiate between ' and
", but I agree that might break stuff for people that are used to the
current behaviour of OGR.
So to complete the same example as in the original message (Äüß is the name
of a field, vÄüß is just a string value):
Name = ‘vÄüß’ -> no error, correctly filtered
Äüß = ‘vÄüß’ -> error (SQL Expression Parsing Error: syntax error) (Would
be nice if this would work)
'Äüß' = ‘vÄüß’ -> no error, but it actually filters Äüß = ‘vÄüß’ (IMO this
should only compare the strings and therefor return no results)
"Äüß" = ‘vÄüß’ -> no error, and it correctly filters Äüß = ‘vÄüß’
"Äüß" = "vÄüß" -> no error, but it actually filters Äüß = ‘vÄüß’ (I would
prefer a parsing error here)
Regards,
Dennis
On Mon, Apr 8, 2013 at 9:53 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> > About the repacking of shapefiles with .cpg, could you create a ticket
> > about that ? thanks.
> I've just fixed that issue in trunk, so you don't need to create a ticket.
> > Best regards,
> > Even
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130409/02e3e62b/attachment.html>
