[gdal-dev] Compile GDAL/OGR with SOSI support
SBL
Stefan.Blumentrath at nina.no
Fri Apr 12 02:26:23 PDT 2013
Hi
New update on this issue:
Now I finally managed to build GDAL/OGR with SOSI support on Ubuntu 12.04,
thanks to the Help of Thomas.
First I compiled the new Version he provided for the FYBA-lib:
Then some changes in the GNUmakefiles in the GDAL-source were necessary.
A version with these changes can (at the moment) be found on:
https://github.com/kartverket/gdal
So I did:
Please note that in the GDAL-version above, SOSI-support is allways
activated.
It would be great if the changes could be somehow re-integrated into the
gdal-project, in a modified way which will offer a --with-sosi option on
./configure (optimal also with feedback like "SOSI support: yes/no").
The SOSI-driver has been successfully tested with recent SOSI-files...
Cheers
Stefan
View this message in context: http://osgeo-org.1560.x6.nabble.com/Compile-GDAL-OGR-with-SOSI-support-tp5045207p5046341.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
