[gdal-dev] gdal_translate using a wms as input
Tyler Mitchell
Tyler.Mitchell at actian.com
Sat Apr 13 13:27:57 PDT 2013
I'm not at my desk right now but I thought adding -outsize x y would do the trick?
On 2013-04-13, at 1:21 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le samedi 13 avril 2013 22:10:07, Andrea Peri a écrit :
>> Hi,
>> I'm try-ing to get a raster from a wms service using gdal_translate
>> this is the call I'm doing:
>> gdal_translate -of GTiff -co "TFW=Y
>> ES" -srcwin 0 0 377 283 "WMS:
>> http://www502.regione.toscana.it/cartografia/wmsras
>> ter/com.rt.wms.RTmap/wms?map=wmsofc&language=ita&&SERVICE=WMS&VERSION=1.3.0
>> &REQU
>> EST=GetMap&BBOX=1671200.0,4680000.0,1672800.0,4681200.0&CRS=EPSG:3003&WIDT
>> H=377&
>> HEIGHT=283&LAYERS=rt_ofc.10k10&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLU
>> TION=9 6&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE" output_01J31.tif
>> But it give me this error:
>> Input file size is 1073741824, 805306368
>> 0ERROR 2:
>> jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE,
>> band 2: Out of memory in InitBlockInfo().
>> If I try the sam wms request on a browser it work so
>> I don't understand what is wrong.
> This is due how GDAL manages rasters. It allocates a block cache array. For
> such huge rasters as WMS layers, the dimensions of the block cache can be huge
> themselves. In your case, the block cache dimensions are (1073741824 / 64 /
> 1024) * (805306368 / 64 / 1024) = 16 384 * 12 288 = 201 millions blocks -->
> 800 MB on a 32 bit OS.
> I've tested the above on a Linux 64bit machine, and it works due to more
> virtual memory available (on Linux, the 800 MB, well 1.6 GB on 64bit, wouldn't
> actually be allocated right away, but only reserved due to virtual memory
> overcommit mechanism ).
> The way the block cache is managed is clearly not satisfactory for huge
> rasters such as WMS. There's a proposed RFC (
> http://trac.osgeo.org/gdal/wiki/rfc26_blockcache ) to address that, but it is
> not yet implemented.
>> Any help is welcome,
>> thx
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
