[gdal-dev] lib to get from GDAL/geotiff to PROJ4
wsvries wsvries at xs4all.nl
Wed Apr 17 04:23:01 PDT 2013
I am working on an application (adding terrain info to maps for 3D
rendering) that does some heavy projection calculations using the proj4
libs.
Input for now is geotiff.
I have Googled a lot, but I was not able to find any libs that can
output proj4 strings based on geotiff input.
I have seen (GDAL based) utilities that are able to do that but no libs
to use in my application.
Any hint is welcome.
Thanks.
