[gdal-dev] Missing geometry type when using ogr2ogr to write FileGDB
Stefan Keller
sfkeller at gmail.com
Sun Apr 21 10:20:18 PDT 2013
Weird enough, this ogrinfo command works
$ ogrinfo -ro WFS:
http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E
INFO: Open of `WFS:
http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E'
using driver `WFS' successful.
1: pois (Point)
This works too but stumbles over any additional URL parameters:
$ ogrinfo -ro WFS:
http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E&SERVICE=WFS&TYPENAME=pois
INFO: Open of `WFS:
1: pois (Point)
'SERVICE' is not recognized as an internal or external command,
operable program or batch file.
'TYPENAME' is not recognized as an internal or external command,
Yours, Stefan
2013/4/21 Stefan Keller <sfkeller at gmail.com>
> Many thanks for the quick reply, Even!
> You're right, it seems to work with Shapefile - but not for the WFS reader
> (and own server) we are testing...
> Below you find the GML output of our WFS source.
> So is the "fault" in the WFS reader - or even in our WFS Response XML?
> Yours, Stefan
> Testing OpenPOIMap WFS Service
> Get all hostels of Switzerland from OpenStreetMap database
> ("tourism=hostel"). Response edited:
> GetCapabilities:
> http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E&SERVICE=WFS&REQUEST=GetCapabilities
> Response => (...)
> GetFeature:
> http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=pois&SRSNAME=EPSG:4326
> Response =>
> <wfs:FeatureCollection
> xmlns:fs="http://example.com/featureserver"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengeospatial.net//wfs/1.0.0/WFS-basic.xsd">
> <gml:featureMember gml:id="-324390">
> <fs:pois fid="-324390">
> <fs:way>
> <gml:Point srsName="EPSG:4326">
> <gml:coordinates decimal="." cs="," ts="
> ">6.59728931318,46.5195096642</gml:coordinates>
> </gml:Point>
> </fs:way>
> <fs:shop>None</fs:shop>
> <fs:amenity>None</fs:amenity>
> <fs:surface>None</fs:surface>
> <fs:street>None</fs:street>
> </fs:pois>
> </gml:featureMember>
> </wfs:FeatureCollection>
> 2013/4/21 Even Rouault <even.rouault at mines-paris.org>
>> Le dimanche 21 avril 2013 17:49:28, Stefan Keller a écrit :
>> > When trying to use ogr2ogr (ver. 1.9) to convert a Shapefile (geometry
>> type
>> > Polygon) to file geodatabase (FileGDB) I'm getting an error like "FGDB
>> > layers cannot be created with a wkbUnknown layer geometry type.":
>> > $ ogr2ogr -f filegdb out.gdb polygon.shp
>> > When adding -nlt it seems to work:
>> > $ ogr2ogr -f filegdb out.gdb polygon.shp -nlt POLYGON
>> > This is to a) an usual OGR behavior, and b) a show stopper for my script
>> > because I don't know before hand (and won't check with ogrinfo) what
>> > geometry type the input source is. Seems like there is a problem in the
>> > FileGDB driver.
>> > Can anybody confirm and explain this bug?
>> Stefan,
>> I don't confirm that behaviour with either 1.9.2 or 1.10.0. Conversion
>> works
>> fine for me without specifying -nlt. What is the geometry type reported by
>> ogrinfo on polygon.shp ?
>> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130421/39614d6e/attachment-0001.html>
