[gdal-dev] GDAL Raster Attribute Tables.
Tue Apr 23 15:17:41 PDT 2013
Peter,
Actually, I should have added that I think a following stage should be for
you to prepare a formal detailed RFC proposal for voting on by the PSC
rather than just throwing a patch at us since this is an API change.
Best regards,
Frank
On Tue, Apr 23, 2013 at 3:16 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> On Tue, Apr 23, 2013 at 1:57 PM, Peter Bunting <petebunting at mac.com>wrote:
>> Hi All,
>> We were wondering if there is any interest in the GDAL community for
>> improving the Raster Attribute Implementation? Within our group of
>> collaborators we have been representing image segmentations as clump files
>> often large attribute tables containing millions of rows and numerous
>> columns of data used for classification. We are finding the current
>> approach that reads a single value at a time with the whole attribute table
>> in memory to be quite poor performance wise and resource (i.e., memory)
>> hungry.
> Peter,
> You do seem to be pushing raster attribute tables well beyond the expected
> use cases.
>> We would like to propose a new implementation that allows reading and
>> writing of whole chunks of a single column within the attribute table more
>> like RasterIO.
>> If we were to create a patch, would the GDAL community be receptive to
>> this? We were thinking this would be incorporated within the interface
>> changes in GDAL 2.0.
> I would be receptive to additional read (and perhaps write) methods for
> chunks of the attribute table at a time if it can be done with a minimum of
> distruption of the existing api.
>> It has been muted that OGR might be merged into GDAL in version 2.0 if
>> this were to occurred how would attribute tables be dealt with and are the
>> changes we proposing something that needs to be considered in that wider
>> context also?
> I had not been contemplating treating raster attribute tables as OGR
> layers.
> I must confess that I'm still not certain that pushing raster attribute
> tables to be very large is a good idea.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130423/cc2e7d58/attachment-0001.html>
