[gdal-dev] GetGeoTransform() valid?
Wim de Vries
wsvries at xs4all.nl
Wed Apr 24 00:21:51 PDT 2013
Thanks for taking the time to answer.
On 04/24/2013 02:07 AM, Frank Warmerdam wrote:
> Is the relationship between your images and geographic (lat/long)
> coordinate space affine? If so, a geotransform will do just fine.
> (ie. is the pixel spacing uniform over the image in terms of decimal
> degrees)
If I understand you correctly, it cannot be used for e.g. a lambert
conformal > cartesian (eg. bitmap x,y pixels), because lons are not
parallel and lats are bend when being projected.
regards,
wim
BTW; I want to use GDAL for an OS flight navigation project
(http://openflightnav.org/)
> Best regards,
> Frank
> On Tue, Apr 23, 2013 at 4:37 AM, Wim de Vries <wsvries at xs4all.nl
> <mailto:wsvries at xs4all.nl>> wrote:
> Hi,
> I want to go from x,y (pixels) to lon,lat and vice versa, using
> geotiffs.
> I have found the GetGeoTransform()
> <http://www.gdal.org/classGDALDataset.html#af9593cc241e7d140f5f3c4798a43a668>
> function, but the documentations says:
> "NOTE: GetGeoTransform()
> isn't expressive enough to handle the variety of OGC Grid
> Coverages pixel/line to projection transformation schemes.
> Eventually this method will be depreciated in favour of a more
> general scheme."
> I googled a lot, but cannot find out what is meant exactly by "OGC
> Grid Coverages". I am just working with a simple cartesian x,y grid.
> Anyone willing to explain a bit more.
> Thanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130424/09eda1ff/attachment.html>
