[gdal-dev] Geopdf dependency on Poppler and Visual Studio 2012
Jeff Lacoste jefflacostegdal at gmail.com
Fri Apr 26 05:28:26 PDT 2013
Thanks Joaquim. I now managed to build Poppler using freetype as its only
dependency.
Do we know if GDAL GeoPdf driver needs 'Poppler' to be built with other
dependencies that can come with Poppler: lcms, icon, openjpeg, tiff, etc.
To have Geopdf driver work correctly using 'Poppler' are these dependencies
needed ? or all it needs is 'Freetype' and 'enable-xpdf-headers' ?
Thanks
Jeff
On Thu, Apr 25, 2013 at 10:40 AM, Joaquim Luis <jluis at ualg.pt> wrote:
>  Jeff,
> I built it from from source (from the git repo actually) and don't
> remember to have had any particular problem. They provide a cmake solution,
> which creates only a static lib but it linked fine with my VS2012 GDAL
> build.
> Joaquim
>  Hi,
>  I'm trying to build GDAL using Visual Studio 2012 and run into an issue
> with Geopdf format.
> This format depends on Poppler (or podofo) 3rd party component.
> Is there a VS 2012 compatible Poppler library for win32 and x64 bits ?
>  I downloaded the Poppler library from http://vbkto.dyndns.org:1280/sdk/ but
> it appears
> to be a static .lib built using Visual Studio 2010. If it was a stub .lib
> (with run time .dll) I can
> consume it from Visual Studio 2012, but its unfortunately a static .lib
> (that VS 2012 can not link without errors).
>  Thanks
> Jeff
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130426/f2f08ed5/attachment.html>
