[gdal-dev] Regarding ogr Layer Attribute properties corruption
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Fri Apr 26 06:22:51 PDT 2013
Abhinav <abhinav <at> vizexperts.com> writes:
> Hi All,
> When I write the OGR layer and read that back, layer attributes properties
> are getting lost like width, precision .These properties are coming zero(0)
> for every attribute. I am trying to write ogrlayer to sqlite file. Is this
> the issue with sqlite driver or gdal itself?
More details would be appreciated. Like the exact command if you are using
org2ogr or some code if you are doing it with your own program.
-Jukka Rahkonen-
