[gdal-dev] GDAL/OGR 1.10.0 released
Even Rouault
even.rouault at mines-paris.org
Mon Apr 29 11:42:44 PDT 2013
The GDAL/OGR team is pleased to announce the release of GDAL/OGR 1.10.0.
This is a major new release including the following major new features:
* New GDAL drivers:
- ARG: read/write support for the Azavea Raster Grid format (#4591)
- CTable2: read/write support for CTable2 datum grid shift format
- DDS: write-only support for DirectDraw Surface format (#5017)
- IRIS: read support for products generated by the IRIS weather radar
software (#4854)
- MAP: read OziExplorer .map files (#3380)
- MBTiles: read-only support for MBTiles rasters
* New OGR drivers:
- ElasticSearch: write-only support to write into ElasticSearch databases
- ODS : read/write support for OpenOffice .ods (Open Document Spreadsheets)
- OSM : read-only support for .osm / .pbf OpenStreetMap files
- PDF: read/write support for vector/structured PDF files
- XLSX: read/write support for MS Excel 2007 and later Open Office XML .xlsx
spreadsheets
* RFC 39: OGR Layer algebra methods :
http://trac.osgeo.org/gdal/wiki/rfc39_ogr_layer_algebra
* SQL SQLite dialect : http://gdal.org/ogr/ogr_sql_sqlite.html
* Make GDAL loadable as a SQLite3 extension (named VirtualOGR) (#4782)
* /vsicurl_streaming/: new virtual file system handler designed to read in
streaming mode dynamically generated files
* GDAL API_PROXY mechanism to run GDAL drivers in a separate process:
http://gdal.org/gdal_api_proxy.html
* Significantly improved drivers : PDF, SQLite, JP2OpenJPEG
* Geocoding client : http://gdal.org/ogr/ogr__geocoding_8h.html
* Upgrade to EPSG 8.0 database
Complete news on the new release can be found at:
http://trac.osgeo.org/gdal/wiki/Release/1.10.0-News
The new release can be downloaded from:
* http://download.osgeo.org/gdal/1.10.0/gdal1100.zip - source as a zip
* http://download.osgeo.org/gdal/1.10.0/gdal-1.10.0.tar.gz - source as
.tar.gz
* http://download.osgeo.org/gdal/1.10.0/gdalautotest-1.10.0.tar.gz - test
suite
* http://download.osgeo.org/gdal/1.10.0/gdal1100doc.zip - documentation /
website
From now, http://download.osgeo.org/gdal/CURRENT link also point to the latest
release.
Best regards,
Even
