[gdal-dev] Build GDAL with OCI support on Linux
Ivan Lucena ivan.lucena at princeton-ma.us
Mon Apr 29 13:53:34 PDT 2013
Hi Rui,
>  -------Original Message-------
>  From: Rui Cavaco <rcavaco at sig2000.pt>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Build GDAL with OCI support on Linux
>  Sent: Apr 29 '13 15:29
>  Hello!
>  I'm trying to get OCI support in GDAL / OGR in Ubuntu 12.04 32-bit.
>  I've successfully installed Oracle Instant Client 11_2 . SQLPlus works
>  flawlessly.
>  Building GDAL also ended with no errors.
>  But executing ogrinfo --formats, OCI format is not listed.
>  Building script is:
>  export LDFLAGS="-Wl,-no-as-needed"
>  ./configure \
>     --with-python --with-libkml=no --with-geotiff=internal \
>     --with-threads --with-libtiff=internal --with-geotiff=internal
>  --with-jpeg=internal --with-gif=internal --with-png=internal
>  --with-libz=internal \
>     --with-oci=yes \
>  --with-oci-include=/usr/lib/oracle/instantclient_11_2/sdk/include \
>     --with-oci-lib=/usr/lib/oracle/instantclient_11_2
>  make
>  sudo make install
>  Environment variables:
>  LD_LIBRARY_PATH=/usr/local/pgsql/lib:/usr/lib/oracle/instantclient_11_2:/usr/local/lib:
>  PATH=/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/lib/oracle/instantclient_11_2
>  In Config.log, we can see:
>  configure:22485: checking for Oracle OCI headers in
>  configure:22518: g++ -c -g -O2
>  -I/usr/lib/oracle/instantclient_11_2/sdk/include conftest.cpp >&5
>  configure:22518: $? = 0
>  configure:22531: result: yes
>  configure:22552: checking for Oracle OCI libraries in
>  configure:22578: g++ -o conftest -g -O2
>  -I/usr/lib/oracle/instantclient_11_2/sdk/include -Wl,-no-as-needed
>  -L/usr/lib/oracle/instantclient_11_2 -lclntsh conftest.cpp -L/usr/lib
>  -lpq -lpthread -lm -lrt -ldl  >&5
>  configure:22578: $? = 0
>  configure:22582: result: yes
>  configure:22626: checking if Oracle OCI version is >= 10.0.1
>  configure:22646: result: yes
>  configure:22649: checking for Oracle version >= 10.x to use -lnnz10 flag
>  configure:22654: result: yes
>  configure:22675: checking if Oracle support is enabled
>  configure:22689: result: yes
>  configure:24105: checking for Oracle OCI headers in
>  configure:24138: g++ -c -g -O2
>  configure:24138: $? = 0
>  configure:24151: result: yes
>  configure:24172: checking for Oracle OCI libraries in
>  configure:24198: g++ -o conftest -g -O2
>  -L/usr/lib/oracle/instantclient_11_2 -lclntsh conftest.cpp -lexpat
>  -L/usr/lib -lpq -lpthread -lm -lrt -ldl  >&5
>  configure:24198: $? = 0
>  configure:24202: result: yes
>  configure:24246: checking if Oracle OCI version is >= 8.1.7
>  configure:24266: result: yes
>  configure:24269: checking for Oracle version >= 10.x to use -lnnz10 flag
>  configure:24274: result: yes
>  configure:24295: checking if Oracle support is enabled
>  configure:24309: result: yes
>  Apparently, no errors to be found.
>  But OGR tools cannot access Oracle datasources.
What is the command line and the error message that tells you that?
Can you see OCI as one of the driver when you run "ogrinfo --formats" ?
There was a discussion about building GDAL on Ubuntu on OTN:
https://forums.oracle.com/forums/thread.jspa?threadID=1128217&tstart=0&messageID=10658264#10658264
Regards,
Ivan
>  Hoping to get some help on this,
>  Rui Cavaco
>  Mail: rcavaco at sig2000.pt
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
