[gdal-dev] Overflow in geojson values
Dmitriy Baryshnikov
bishop.dev at gmail.com
Thu Aug 1 12:56:26 PDT 2013
GDAL GeoJSON driver use modified and outdated json-c. It seem to me that
this is the bug and ticket in track needed.
Best regards,
Dmitriy
01.08.2013 22:31, Smith, Michael ERDC-RDE-CRREL-NH пишет:
> Unfortunately, that¹s after the data has been read and overflowed.
> The time should be 1375291903959.
> Updated should be 1375295733317.
> Mike
> On 8/1/13 2:21 PM, "Kyle Shannon" <kyle at pobox.com> wrote:
>> On Thu, Aug 1, 2013 at 11:36 AM, Smith, Michael ERDC-RDE-CRREL-NH
>> <Michael.Smith at erdc.dren.mil> wrote:
>>> I'm reading a geojson feed put out by the USGS
>>> (http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson
>>> but the time/updated values are overflowing. Are there any settings to
>>> allow
>>> the data to come across as bigint or strings?
>>> For example:
>>> {"type":"Feature","properties":{"mag":0.46,"place":"2km W of Lemmon
>>> Valley,
>>> Nevada","time":1375291903959,"updated":1375295733317,"tz":-420,"url":"htt
>>> p://earthquake.usgs.gov/earthquakes/eventpage/nn00419191","detail":"http:
>>> //earthquake.usgs.gov/earthquakes/feed/v1.0/detail/nn00419191.geojson","f
>>> elt":null,"cdi":null,"mmi":null,"alert":null,"status":"REVIEWED","tsunami
>>> ":null,"sig":3,"net":"nn","code":"00419191","ids":",nn00419191,","sources
>>> ":",nn,","types":",cap,general-link,geoserve,nearby-cities,origin,","nst"
>>> :12,"dmin":0.069,"rms":0.1034,"gap":74,"magType":"ml","type":"earthquake"
>>> },"geometry":{"type":"Point","coordinates":[-119.8773,39.632,5.0829]},"id
>>> ":"nn00419191"}
>>> Gets returned as
>>> OGRFeature(OGRGeoJSON):176
>>> mag (Real) = 1.7
>>> place (String) = 21km S of Lowell, Oregon
>>> time (Integer) = 902732480
>>> updated (Integer) = 903846662
>>> tz (Integer) = -420
>>> url (String) =
>>> http://earthquake.usgs.gov/earthquakes/eventpage/uw60561592
>>> detail (String) =
>>> http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/uw60561592.geojso
>>> n
>>> felt (String) = (null)
>>> cdi (String) = (null)
>>> mmi (String) = (null)
>>> alert (String) = (null)
>>> status (String) = REVIEWED
>>> tsunami (String) = (null)
>>> sig (Integer) = 44
>>> net (String) = uw
>>> code (String) = 60561592
>>> ids (String) = ,uw60561592,
>>> sources (String) = ,uw,
>>> types (String) = ,cap,general-link,geoserve,nearby-cities,origin,
>>> nst (Integer) = (null)
>>> dmin (Real) = 0.24254513
>>> rms (Real) = 0.24
>>> gap (Real) = 118.8
>>> magType (String) = Md
>>> type (String) = quarry
>>> POINT (-122.7927 43.7262 0)
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Try the cast operator in ogr sql:
>> kyle at kyle-workstation:~$ ogrinfo -sql 'select *, cast(time as
>> character(0)),cast(updated as character(0)) from OGRGeoJSON'
>> /vsicurl/http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.
>> geojson
>> OGRFeature(OGRGeoJSON):185
>> mag (Real) = 2.4
>> place (String) = 29km N of Brenas, Puerto Rico
>> time (Integer) = 905049680
>> updated (Integer) = 908474945
>> tz (Integer) = -240
>> url (String) =
>> http://earthquake.usgs.gov/earthquakes/eventpage/pr13212004
>> detail (String) =
>> http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/pr13212004.geojson
>> sig (Integer) = 89
>> net (String) = pr
>> code (String) = 13212004
>> ids (String) = ,pr13212004,
>> sources (String) = ,pr,
>> types (String) = ,cap,geoserve,nearby-cities,origin,tectonic-summary,
>> nst (String) = 13
>> dmin (Real) = 0.30722383
>> rms (Real) = 0.27
>> gap (Real) = 219.6
>> type (String) = earthquake
>> time (String) = 905049680
>> updated (String) = 908474945
>> POINT (-66.3495 18.7346 29)
>> note the values at the bottom, time and update as (String). You could
>> write the entire field list in the sql and substitue time and updated
>> for the casted values.
>> kss
