[gdal-dev] Overflow in geojson values
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 1 13:36:11 PDT 2013
On Thu, Aug 1, 2013 at 1:32 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Dmitriy Baryshnikov <bishop.dev at gmail.com>:
> > Hi,
> > GDAL GeoJSON driver use modified and outdated json-c. It seem to me that
> > this is the bug and ticket in track needed.
> It would be a 2 step work. I indeed see that newer json-c supports int64,
> so a
> first step would be to make the GeoJSON driver uses the new json-c 64 bit
> API.
> But OGR does not support int64 yet, so the overflow would occur just
> afterwards.
> There's an RFC ( http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64 ) about that
> waiting for implementation.
Folks,
Also waiting for final refinement and adoption...
I think I'd like to revisit this issue before the next major release since
it is negatively impacting a number of drivers - not just geojson.
Best regards,
Frank
> Best regards,
> Even
> > Best regards,
> > Dmitriy
> > 01.08.2013 22:31, Smith, Michael ERDC-RDE-CRREL-NH Ð¿ÐžÑ ÐµÑ :
> > > Unfortunately, that¹s after the data has been read and overflowed.
> > > The time should be 1375291903959.
> > > Updated should be 1375295733317.
> > > Mike
> > > On 8/1/13 2:21 PM, "Kyle Shannon" <kyle at pobox.com> wrote:
> > >> On Thu, Aug 1, 2013 at 11:36 AM, Smith, Michael ERDC-RDE-CRREL-NH
> > >> <Michael.Smith at erdc.dren.mil> wrote:
> > >>> I'm reading a geojson feed put out by the USGS
> http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson
> > >>> but the time/updated values are overflowing. Are there any settings
> to
> > >>> allow
> > >>> the data to come across as bigint or strings?
> > >>> For example:
> > >>> {"type":"Feature","properties":{"mag":0.46,"place":"2km W of Lemmon
> > >>> Valley,
> Nevada","time":1375291903959,"updated":1375295733317,"tz":-420,"url":"htt
> > >>> p://earthquake.usgs.gov/earthquakes/eventpage/nn00419191
> ","detail":"http:
> earthquake.usgs.gov/earthquakes/feed/v1.0/detail/nn00419191.geojson","f
> elt":null,"cdi":null,"mmi":null,"alert":null,"status":"REVIEWED","tsunami
> ":null,"sig":3,"net":"nn","code":"00419191","ids":",nn00419191,","sources
> ":",nn,","types":",cap,general-link,geoserve,nearby-cities,origin,","nst"
> :12,"dmin":0.069,"rms":0.1034,"gap":74,"magType":"ml","type":"earthquake"
> },"geometry":{"type":"Point","coordinates":[-119.8773,39.632,5.0829]},"id
> > >>> ":"nn00419191"}
> > >>> Gets returned as
> > >>> OGRFeature(OGRGeoJSON):176
> > >>> mag (Real) = 1.7
> > >>> place (String) = 21km S of Lowell, Oregon
> > >>> time (Integer) = 902732480
> > >>> updated (Integer) = 903846662
> > >>> tz (Integer) = -420
> > >>> url (String) =
> > >>> http://earthquake.usgs.gov/earthquakes/eventpage/uw60561592
> > >>> detail (String) =
> http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/uw60561592.geojso
> > >>> n
> > >>> felt (String) = (null)
> > >>> cdi (String) = (null)
> > >>> mmi (String) = (null)
> > >>> alert (String) = (null)
> > >>> status (String) = REVIEWED
> > >>> tsunami (String) = (null)
> > >>> sig (Integer) = 44
> > >>> net (String) = uw
> > >>> code (String) = 60561592
> > >>> ids (String) = ,uw60561592,
> > >>> sources (String) = ,uw,
> > >>> types (String) = ,cap,general-link,geoserve,nearby-cities,origin,
> > >>> nst (Integer) = (null)
> > >>> dmin (Real) = 0.24254513
> > >>> rms (Real) = 0.24
> > >>> gap (Real) = 118.8
> > >>> magType (String) = Md
> > >>> type (String) = quarry
> > >>> POINT (-122.7927 43.7262 0)
> > >>> _______________________________________________
> > >>> gdal-dev mailing list
> > >>> gdal-dev at lists.osgeo.org
> > >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > >> Try the cast operator in ogr sql:
> > >> kyle at kyle-workstation:~$ ogrinfo -sql 'select *, cast(time as
> > >> character(0)),cast(updated as character(0)) from OGRGeoJSON'
> > >> /vsicurl/
> > >> geojson
> > >> OGRFeature(OGRGeoJSON):185
> > >> mag (Real) = 2.4
> > >> place (String) = 29km N of Brenas, Puerto Rico
> > >> time (Integer) = 905049680
> > >> updated (Integer) = 908474945
> > >> tz (Integer) = -240
> > >> url (String) =
> > >> http://earthquake.usgs.gov/earthquakes/eventpage/pr13212004
> > >> detail (String) =
> http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/pr13212004.geojson
> > >> sig (Integer) = 89
> > >> net (String) = pr
> > >> code (String) = 13212004
> > >> ids (String) = ,pr13212004,
> > >> sources (String) = ,pr,
> > >> types (String) =
> ,cap,geoserve,nearby-cities,origin,tectonic-summary,
> > >> nst (String) = 13
> > >> dmin (Real) = 0.30722383
> > >> rms (Real) = 0.27
> > >> gap (Real) = 219.6
> > >> type (String) = earthquake
> > >> time (String) = 905049680
> > >> updated (String) = 908474945
> > >> POINT (-66.3495 18.7346 29)
> > >> note the values at the bottom, time and update as (String). You could
> > >> write the entire field list in the sql and substitue time and updated
> > >> for the casted values.
> > >> kss
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130801/cf3354e5/attachment-0001.html>
