[gdal-dev] OGDI dead?
William Kyngesburye
woklist at kyngchaos.com
Mon Aug 5 07:25:56 PDT 2013
I figured out why it stopped working, then started working again - I had disabled GDAL 1.9 (OS X framework), which has OGDI libraries bundled in it. My OGDI library was built when 1.9 was current, and I just changed the library loader (system) paths to bundle it with GDAL 1.10. I didn't realize that OGDI also has its own path hardwired into it to find the modules, and it's a full path, not relative.
After restoring GDAL 1.9, OGDI worked again from GDAL 1.10 (but it still probably has the libdtusa issue, if ever used).
So, I DO need to rebuild OGDI to update the module path, so GDAL 1.10 doesn't need 1.9.
On Aug 4, 2013, at 11:26 PM, Frank Warmerdam wrote:
> William,
> Interesting point. It would appear I'll need to do a few small fixes to OGDI to keep it building, though I normally just work around the projects.h one. In fact, I'm only vaguely familiar with the existance and role of libdtusa.so so perhaps that has been broken for a while too.
> Best regards,
> Frank
> On Sun, Aug 4, 2013 at 11:44 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Odd, it's working now. Though I'm guessing that it will fail if it tries to load libdtusa.so to do a datum transform (or whatever it does with libdtusa.so). Is this even possible from GDAL?
> On Aug 4, 2013, at 12:23 AM, William Kyngesburye wrote:
> > When doing some dependency updating for my GDAL I noticed that OGDI stopped working, and it looks like it's because of a change in PROJ 4.8 - not only was the projects.h removed from installation, but the nad_init call changed (ie binary incompatibility).
> > There hasn't been a release since the 3.2 beta 2 in 2008, and neither has the cvs source on Sourceforge been updated. There is a bug report there about this PROJ issue from over a year ago.
> > Will this ever be fixed? Is there a simple patch to fix it?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
