[gdal-dev] Reading error with dwg and dxf files
Even Rouault
even.rouault at mines-paris.org
Mon Aug 5 13:23:07 PDT 2013
Selon Xian Chen/³ÂÏÛ <chenxian at walkinfo.com.cn>:
> Thanks Even.
> After checking the code under dwg and dxf, I believe the relevant error code
> to my original error report should be in
> ogr/ogrsf_frmts/dxf/ogrdxf_polyline_smooth.cpp. The code in EmitArc() must
> consider the case when ogrArcStartAngle > ogrArcEndAngle and bClockWise is
> true before calling OGRGeometryFactory::approximateArcAngles() (around line
> 265). Here I increase the value of ogrArcEndAngle by 360 degree as follows:
> if( bClockwise && (ogrArcStartAngle > ogrArcEndAngle) )
> ogrArcEndAngle += 360.0;
> Then the reported error is corrected.
> Similarly, there are error codes in both ogrdxf_hatch.cpp and
> ogrdwg_hatch.cpp as you mentioned.
> Line 286-294 in ogrdxf_hatch.cpp are quite suspicious:
> if( bCounterClockwise )
> double dfTemp = dfStartAngle;
> dfStartAngle = dfEndAngle;
> dfEndAngle = dfTemp;
> if( dfStartAngle > dfEndAngle )
> dfEndAngle += 360.0;
> Can anyone explain to me why switching Start Angle and End Angle (this will
> reverse the order of the line string!!). Also, if bCounterClockwise, you
> won't want to increase dfEndAngle by 360..
> I've fixed the above code with something like:
> dfStartAngle *= -1;
> dfEndAngle *= -1;
> else if( dfStartAngle > dfEndAngle )
> Similar fix-up is made in ogrdwg_hatch.cpp
> Not sure if these are sufficient, yet at least work well with my couple of
> sample dwg/dxf files.
> I may want to submit a patch if you and other developers are okay with my
> fix-up.
Xian,
I'm not familiar with that code, so I am not sure about your proposed fix, but
it could be helpful if you attach it to a ticket so it doesn't get lost.
Attaching sample .dxf and .dwg files that have the issue that the patch fixes
would also be helpfull.
Best regards,
Even
