[gdal-dev] concatenated VRT file
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Aug 6 02:21:08 PDT 2013
Not sure if this is possible, but perhaps someone here knows a trick.
I use a VRT file as an index to a large set of detailed, tiled scans of
the Netherlands, built with gdalbuildvrt. I recently discovered how to
transform this map on the fly, so that it  exactly aligns to older maps
in different coordinate systems. It's just a matter of adapting the
<geotransform> item in the VRT file.
So I can copy the VRT file for every old map, and adapt the
<geotransform> in each of them. This means that all VRT files will be
identical, except for the <geotransform> line. The VRT files are quite
large, because they cover lots of tiles. Can anyone here think of a
method to do this with one central VRT file, in which only the
<geotransform> line is plugged that is required for the particular old
map?  Something like a symbolic link to concatenate the variable and
stable parts of the VRT file?
Jan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130806/0bdc214f/attachment-0001.html>
