[gdal-dev] netCDF Data without subdatasets
Gunnar Oehmichen
oehm8895 at uni-landau.de
Tue Aug 6 07:38:42 PDT 2013
this is my first time using netcdf data and gdal library on Ubuntu 12.04
I have downloaded a subsetted monthly precipitation dataset from:
http://www.esrl.noaa.gov/psd/data/gridded/data.cmap.html
I want to create timelines of a few gridcells (covering germany)
As I understand, before converting bands to raster-images by
gdal_translate one has to extract information from the subdatasets.
My Problem is:
using
gdalinfo X139.14.20.244.217.3.48.41.nc > gdalinfo.txt
No subdatasets appear. I would have expected something like to the
follwing to be included in the output of gdalinfo:
SUBDATASET_1_NAME=NETCDF:...
SUBDATASET_1_DESC=...
SUBDATASET_2_NAME=...
SUBDATASET_2_DESC=...
SUBDATASET_3_NAME=...
SUBDATASET_3_DESC=...
Instead the output is as following:
Driver: netCDF/Network Common Data Format
Files: X139.14.20.244.217.3.47.29.nc
Size is 6, 5
Coordinate System is `'
Origin = (2.500000000000000,57.500000000000000)
Pixel Size = (2.500000000000000,-2.500000000000000)
Metadata:
lat#actual_range={ 56.25, 46.25 }
lat#axis=Y
lat#long_name=Latitude
lat#standard_name=latitude
lat#units=degrees_north
lon#actual_range={ 3.75, 16.25 }
lon#axis=X
lon#long_name=Longitude
lon#standard_name=longitude
lon#units=degrees_east
NC_GLOBAL#Conventions=COARDS
NC_GLOBAL#documentation=http://www.esrl.noaa.gov/psd/data/gridded/data.cmap.html
NC_GLOBAL#history=Tue Aug 6 03:47:30 2013: ncks -O -d
lat,46.000000,57.000000 -d lon,3.000000,17.000000 -d time,0,2401
/Datasets/cmap/std/precip.pentad.mean.nc
/Public/www/X139.14.20.244.217.3.47.29.nc
Created by CAS 09/2012 using Version 1201
NC_GLOBAL#platform=Analyses
NC_GLOBAL#references=http://www.esrl.noaa.gov/psd/data/gridded/data.cmap.html
NC_GLOBAL#source=ftp ftp.cpc.ncep.noaa.gov precip/cmap/pentad
NC_GLOBAL#title=CPC Merged Analysis of Precipitation Pentad data
(excludes NCEP Reanalysis I)
NC_GLOBAL#Version=V1201
precip#actual_range={ 0, 25.07 }
precip#add_offset=0
precip#dataset=CPC Merged Analysis of Precipitation Standard
precip#least_significant_digit=2
precip#level_desc=Surface
precip#long_name=Average Pentad Rate of Precipitation
precip#missing_value=-9.96921e+36
precip#parent_stat=Mean
precip#precision=2
precip#scale_factor=1
precip#statistic=Pentad Mean
precip#units=mm/day
precip#valid_range={ 0, 250 }
precip#var_desc=Precipitation
time#actual_range={ 1569072, 1857384 }
time#avg_period=0000-01-00 00:00:00
time#axis=T
time#delta_t=0000-00-05 00:00:00
time#long_name=Time
time#standard_name=time
time#units=hours since 1800-01-01 00:00:0.0
Corner Coordinates:
Upper Left ( 2.5000000, 57.5000000)
Lower Left ( 2.5000000, 45.0000000)
Upper Right ( 17.5000000, 57.5000000)
Lower Right ( 17.5000000, 45.0000000)
Center ( 10.0000000, 51.2500000)
Band 1 Block=6x1 Type=Float32, ColorInterp=Undefined
NoData Value=-9.96920996838686905e+36
Metadata:
add_offset=0
level_desc=Surface
NETCDF_DIMENSION_time=1569072
NETCDF_time_units=hours since 1800-01-01 00:00:0.0
NETCDF_VARNAME=precip
parent_stat=Mean
precision=2
scale_factor=1
units=mm/day
And the next bands following.
Here is the metadata:
Metadata for /Public/www/X139.14.20.244.217.3.47.29.nc
Dimensions:
time 2402
lat 5
lon 6
precip 2402 5 6
Variables:
time
long_name Time
avg_period 0000-01-00 00:00:00
axis T
standard_name time
delta_t 0000-00-05 00:00:00
actual_range 1979-01-01 00:00:00 2011-11-22 00:00:00
units hours since 1800-01-01 00:00:0.0
lat
long_name Latitude
axis Y
standard_name latitude
actual_range 56.25 46.25
units degrees_north
lon
long_name Longitude
axis X
standard_name longitude
actual_range 3.75 16.25
units degrees_east
precip
parent_stat Mean
long_name Average Pentad Rate of Precipitation
valid_range 0 250
least_significant_digit 2
level_desc Surface
dataset CPC Merged Analysis of Precipitation Standard
missing_value -9.96920996838687e+36
statistic Pentad Mean
actual_range 0 25.0699996948242
var_desc Precipitation
add_offset 0
precision 2
units mm/day
scale_factor 1
Global Attributes:
source
Version
V1201
history
Tue Aug 6 03:47:30 2013: ncks -O -d lat,46.000000,57.000000 -d
/Public/www/X139.14.20.244.217.3.47.29.nc Created by CAS 09/2012 using
Version 1201
references
documentation
platform
Analyses
title
CPC Merged Analysis of Precipitation Pentad data (excludes NCEP
Reanalysis I)
Conventions
COARDS
Any advise on how to proceed to create rasters and timelines from this
would be very appreciated. Probably something obvious I do not see.
Thanks,
Gunnar
