[gdal-dev] Upgrade Python GDAL package in pypi
lpinner Luke.Pinner at environment.gov.au
Tue Aug 6 18:25:52 PDT 2013
If you're installing gdal from ubuntugis, why not install the python bindings
from there also?
sudo apt-get install python-gdal
If this is not an option due to the use of virtualenv, as a workaround until
pypi gets updated you could script the download of the .deb (i.e on 64bit
12.04
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/+files/python-gdal_1.10.0-1%7Eprecise1_amd64.deb),
unzip it and install the bindings to your virtualenv.
Luke
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Upgrade-Python-GDAL-package-in-pypi-tp5071102p5071188.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
