[gdal-dev] FGDB API : field size
Even Rouault
even.rouault at mines-paris.org
Fri Aug 9 11:50:30 PDT 2013
Le vendredi 09 août 2013 09:55:31, xavier lhomme a écrit :
> Hi
> I wonder why for an esriFieldTypeInterger the size is set to 12 (in the
> GDBFieldTypeToWidthPrecision fonction).
> In the xml sample files provided by esri all esriFieldTypeIntergerhas a
> length of 4.
> (and 8 for double) ...
Xavier,
Yes, this doesn't seem consistant with the samples, nor with the spec
(FileGDB_API/xmlResources/FileGDBAPI.xsd).
I've created http://trac.osgeo.org/gdal/ticket/5192 and pushed a fix in trunk.
I'd appreciate if people could generate FileGDB databases with OGR (trunk
after r26283) with various datatypes and check that they can be used OK in
ESRI products.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
