[gdal-dev] Exporting gml3 with OGR for .NET?
Casper Span
info at spatially-oriented.com
Mon Aug 12 04:58:53 PDT 2013
Nobody uses GDAL for .net? :-(
regards,
Casper
On Thu, Aug 8, 2013 at 9:51 AM, Casper Span <info at spatially-oriented.com>wrote:
> Hi list,
> I'm trying to get some piece of code working with the csharp package of
> gdal. (NuGet GDAL / GDAL.Natve).
> Basically, I need to port a geometry to GML3.1.1. According to the
> documentation, all I need to do is add an option "FORMAT=GML3", so I tried
> that:
> using (OSGeo.OGR.Geometry geom = OSGeo.OGR.Ogr.CreateGeometryFromWkt(ref
> wkt, null))
> GmlString = geom.ExportToGML(new string[] { "FORMAT=GML3" });
> But it will still return a GML2 (=default when not using any options)
> text. It really doesn't matter what I pass as an option, it will always
> just return a GML2 string.
> Anybody tried this before?
> regards,
> Casper
> Casper Span
> T: @Span_Droid <https://twitter.com/#%21/Span_Droid>
> W: http://www.spatially-oriented.com
> M: info at spatially-oriented.com
Casper Span
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130812/ffc56b6e/attachment.html>
